Canon Digital Rebel XT / EOS 350D Body only Digital Camera Logo
Posted on Jan 23, 2011
HI! yesterday I charge the battery, and when I want to turn ON camera, there is BUSY flashing on the screen. I`ll try to took off the Cf card and then turn on the camera, but then is nothing on the screen. Like it is turn off. When I back CF card, there is again says "busy". I`l try to took off the battery and put it back, but everything is the same. I can do anything .. Please help!
4 Related Answers
Anonymous
  • 1027 Answers
  • Posted on Jul 10, 2008
SOURCE: anything I can do for a flash busy error 99 message?
Could be that the battery is weak, and should be replaced as it is not holding a charge.
Anonymous
  • 667 Answers
  • Posted on Jul 27, 2008
SOURCE: CF Card is not being read, Canon Digital 350D EOS Problem
It does not sound good. You might want to get a flashlight or similar and look into the memory card slot to check the connector pins in the camera. They may be bent or damaged.
Anonymous
  • 177 Answers
  • Posted on May 24, 2010
SOURCE: I'm trying to transfer my pictures from the camera
Could it be the camera battery is depleted?
Anonymous
  • 62 Answers
  • Posted on Mar 12, 2011
SOURCE: i having canon eos
Hello
The issues you are running into are indicative of two possible issues.
First, the memory card may simply be bad. But before you purchase or try another memory card, you need to look for the second possible issue. The second issue, which is typcially more common, is that inside the card slot on the camera, there are pins, it is possible that one or more of these pins has become bent or damaged. If you look inside you can usually see a pin or pins out of alignment or bent over. If that is the case, the camera will need to go in for service.
I took my CF card out to get photos, went to put it back in and the screen read "There is a problem with CF card. Replace the CF card." I didn't think there was a problem with the card. But I replaced...
Your CF pins in the camera are most likely bent/broken. This is a very common problem. Most repair shops will charge $150-$200 to repair this.
Hope this helps.
Wes
1helpful
2answers
6helpful
2answers
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
1helpful
My canon 20d stopped taking photos for no aparant reason. Kept getting error 99 and when I re insert the battery it starts clicking on it's own whether turned on or not. I sent it to Canon repair who...
If two cameras are doing it, I would suggest the contacts on your lens are dirty.
Try the following diagnosis steps for solving ERR 99 issues : -
3answers
Canon EOS Digital Rebel XTI 400D Displays Err 99. Problem with CF card. Replaced with brand new card-still same err 99 camera is totally charges, acts dead, keep flashing Err CF, I try to format, it...
4. Insert a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Anything I can do for a flash busy error 99 message?
Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
2answers
No take picture!
Hi John,
Try using the AC Adapter as your battery.
[email protected]
"busy" in all modes except non-flash setting on 300d
bad memory card most likely.
try reformatting card in camera.
try battery out for 10 seconds for full reset if that does not work.
may have a problem writing to card.
you can also try another card. cf i believe on that camera.
good luck.
mark
3answers
Busy
Can you try with a new or different CF card,if there is read and write error into CF card camera will gives message "busy".
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
