Toys Logo
Posted on Jan 23, 2011
Do you know where i could find instructions for the game treasure of the pharaohs as i have lost them , thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
264
Points
2answers
Roseart Lego treasure quest instructions
Instructions for RoseArt Lego Treasure Quest game:
  1. Open the game box and remove all components: Make sure to carefully remove all pieces from the box, including the game board, Lego pieces, dice, and game pieces.
  2. Place the game board on a flat surface: Find a flat surface to place the game board on, such as a table or the floor.
  3. Build the Lego treasure chest: Follow the instructions provided to build the Lego treasure chest. This may require sorting and connecting the Lego pieces to create the chest.
  4. Sort the Lego treasure pieces: Sort the treasure pieces into separate piles according to the different types of treasure.
  5. Each player chooses a game piece: Each player should choose a game piece to represent them on the game board.
  6. Roll the dice to determine who goes first: Roll the dice to determine the order in which players will take their turns. The player with the highest roll goes first.
  7. Players take turns rolling the dice and moving their game piece: Players take turns rolling the dice and moving their game piece the number of spaces indicated on the dice. Move the game piece along the path on the game board.
  8. If a player lands on a challenge square, they must complete the challenge: If a player lands on a square with a challenge, they must complete the challenge before continuing their turn. The challenge may require the player to perform a task, answer a question, or complete a mini-game.
  9. The first player to reach the treasure chest and correctly match all of the treasure pieces wins the game: The first player to reach the treasure chest and correctly match all of the treasure pieces wins the game. The player who wins gets to keep the treasure!
Need instructions on a cool blast air cooler
My friend died and her daughter gave me her Cool Blast Unit I don't know if it's a air cooler or an air conditioner. How can I figure out which model this is and how do I run it. Thank you!
Pharaoh and cleopatra freezes constantly
Probably a bit late, but here are the best fixes I found:
First off, you want to:
*** Change compatibility to Windows XP (SP3)
*** Disable Visual Themes
*** Run as admin
Next you want to:
Download the pharaoh exe files (these are for modifying the resolution - this is what worked for me - I used the lowest res available, so I cannot comment on higher ones)
http://www.wsgf.org/dr/cleopatra-queen-nile/en
Or you can try this fix:
https://web.archive.org/web/20080721084339/http://www16.brinkster.com/salvage/thief/imagecfg.zip
"Download ImageCFG
Extract the .zip and place imagecfg.exe in your game's folder.
Create a batch file. First, open up notepad and paste the following.
@echo off
if not exist Pharaoh.exe goto end
if exist Pharaoh.exe.bak goto end
copy Pharaoh.exe Pharaoh.exe.bak
imagecfg -u Pharaoh.exe
imagecfg -a 0x1 Pharaoh.exe
pause
:end
Save as a .bat file and place it in your Pharaoh installation folder.
Run the batch file.
This will change the CPU affinity of Pharaoh so it will run on one CPU core."
This fix taken from here:
http://pcgamingwiki.com/wiki/Pharaoh
1helpful
2answers
I cannot install my pharaoh onto my windows vista. When I clicked the 'Install' button, nothing happened, not even an error message. please help.
Hi guys tried a lot of stuff from a lot of diff websites none worked was about to give up and found this and it worked right of the bat i dont know who the guy is but thanx a Bunch.
http://nienpaper.wordpress.com/2012/01/21/pharaoh-installation-fix-problem/
I have completed the all but the last piece of the first map. I can not figure out the clue for the last piece. There are so many eyepatches through the game I can not understand where to find the one...
Thanks for visiting FixYa!
There are additional specific Gameplay FAQs on the I SPY Treasure Hunt technical support web page. To find these be sure to look through the entire list of FAQs or those related only to gameplay.
    - Insert the I Spy Treasure Hunt CD-ROM in the CD-ROM drive.
    - When the I Spy Treasure Hunt AutoPlay window opens, select the User Guide button. This will open the I Spy Treasure Hunt User Guide in your default web browser.
    - If the AutoPlay windows does not open automatically, double-click the AutoPlay.exe file in the I Spy Treasure Hunt CD-ROM and then select the User Guide button.
Received my Crayola Treasure Adventures Nintendo DS game for my son. The instructions to the game are not in English. Is there any place I can print out the instructions in English.
In Crayola Treasure Adventure, gamers transform their stylus into a crayon and color their way through two modes of play. "Adventure" mode requires players to travel around the globe, to restore the missing hues from each level of play and find the hidden treasure. With the help of a map and a friend named Tip, gamers connect-the-dots, finish jigsaw puzzles, and complete timed mini-games to finish each stage. As each obstacle is completed, players are rewarded with new colors and additional pages for the coloring book. In the "Digital Coloring Book" mode, gamers can use 120 virtual crayons and markers to add their artistic flair to 110 different pictures.
Our old games won't play on the Windows XP system we have.
Hi
You can try windows compatibility mode, you get to this by clicking the start button - accessories - system tools
Choose win 98 or win 95 and see if it works, let me know if you're stuck
Steve :)
I can not get the treasure of alexandria to run on my computer. i need to know how to run it.
Start > Run > type in Dxdiag > save all information > open the saved file > paste it here.
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
