SOURCE: Our Royal Tel-Weight scale shows
The best thing to try is to make sure the battery terminals inside the scale are clean- use a qtip and alcohol, or a pencil eraser. Other than that, there is probably a cracked solder joint on a circuit board inside the unit, not allowing it to initialize. You can try to disassemble the unit, and inspect it to see what the problem is, and possibly resolder the cracked joint. Other than that, a component on the circuit board could be bad, making repair difficult.
Wish I had better news, but hope this helps.
