Nokia 3600 slide Cellular Phone Logo
Anonymous Posted on Jan 23, 2011
My 3600 slide phone shows blank display. - Nokia 3600 slide Cellular Phone
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Jan 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
318
Points
5
If you can receive calls in that state then it is likely to be a problem of data cable connecting main motherboard to that on which lcd is fixed. just substuite it. hope it will solve.my 3600 slide phone shows - mestre_waly.jpg
  • Anonymous Jan 23, 2011
    did it help?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Posted on Jun 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
803
Points
My nokia 3600 slide cant switch on.please help me.........................
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2470202
Points
19564
Please do hard reset on your phone. Re install software if needed
UNlock nokia phone model3600 slide?
Hi, You can unlock a Nokia 3600 SLIDE safer and easier using unlock code. You can get the unlock code for a Nokia 3600 Slide from www.unlock-zone.com/nokia-3600-slide/rs16wp9/ at low cost.
UNLOCKING STEPS FOR A NOKIA 3600 SLIDE
1 - Switch on your Nokia 3600 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3600 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3600 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3600 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 3600 SLIDE
1helpful
Locage Code de restriction nokia 3600 slide imie 359306/02/513989/8
Each Nokia 3600 SLIDE mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 3600 SLIDE mobile phone at www.mobileunlocksolutions.com.
My nokia 3600 slide phone is not switching on. but when i tried to charge it shows charging display. What should i do? Some peoples says the its due to software problem, and can be repaired by flashing. ...
no this is not a software problem, the proble is with the on off power switch, it might e broken or come off the pcb, try shorting two contact with a tweezer phone will power on surely, you can also replace power micro switch at a service center or at home if you know little soldering.
1helpful
My nokia 3600 slide screen kept blank.all of it works fine except the screen
If everything is fine except your screen, bring it to a technician and have them check first the flex wire.
If your flex is fine then the last thing will be your LCD. have it replace
1helpful
Applications for nokia 3600 slide need to be reinstalled
hi thanks for using fixya!!
On this kind of error, I recommend that your bring your phone to a Nokia Care Center to further check the error.
Regards!
Jun 02, 2009 • Nokia 3600
1helpful
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
