If the fan goes off in a few moments after removing the key, it's no issues. The radiator fluid needs to be cooled sufficiently to prevent the engine from overheating and the thermostat clicks off in a few seconds later especially after a hard drive.
If it is not switching off for a long time then you might need to replace the thermostat. You can find a good original low cost one from Low Cost OEM Spares
Fan relay problem. Please replace it accordingly
Probably an 05 or newer with dual zone need to pull the blower motor relay, water goes down the cowl pass side [under the passenger wiper] into the motor and shorts the resister board out.
