Ovens Logo
A
Anonymous Posted on Jan 23, 2011
We have a westinghouse wall oven PON783 and the error of F08 comes up on it regularly not allowing us to use it. It now turns on & off by itself and personally i reakon its dangerous. What needs to be fixed??
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
773
Points
Hi Paulahogan_1, We have had the same F08 error code with our Westinghouse oven. The repairman said its because of two holes drilled in the upper casing of the oven which allow steam to get through to the motherboard - messing with the thermostat I think. The quick fix was pulling out the oven unit by undoing two screws, then undoing two more screws to lift up the motherboard, and filling the two holes with silicone. However, the steam coming through over the last year or so has caused some corrosion of the motherboard, so they're going to replace that given that the oven's still under warranty. Sounds like your oven might have the same problem, but may have suffered more corrosion over time, thereby messing up the controls? Good luck! Hopefully you've already had it fixed by now :)
Westinghouse 662 Oven temp is wrong, by about 100 degree's.
would check to make sure both your broil and bake ignitors are working. On some, but not all, both come on to preheat, and then the broil shuts off. Another, and more likely culprit would be the temperature sensor located in the oven itself. Its the silverish metal rod protruding from the back wall inside the oven. It could be bad and not converting heat/elsectrical signal properly causing the main control to regulate the temperature incorrectly.If the sensor you are talking about is the oven temperature sensor than its just as easy, since you are behind the machine already, to take off the back panal, unplug the sensor and measure resistance there. Either way the resistance should read around 1099-1100 ohms.even a small margine off can cause a major temperature difference.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
1helpful
2answers
Manual required for Westinghouse Wall Oven, Model EW050SB*01.
Please check the user-manuals section within the support page of the New Zealand Westinghouse webssite. You should be able to find your manual there if you search used it's model number.
Thank you.
Jan 01, 2012 • Ovens
3helpful
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
