ATI RADEON HD 2400 PRO Graphic Card Logo
Posted on Jan 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Get "out of range" video display error - screen is
Ali Asghar Khambati
Level 2:
Scholar:
  • Expert 151 Answers
  • Posted on Jan 23, 2011
Ali Asghar Khambati
Expert
Level 2:
Scholar:
Answers
151
Questions
0
Helped
22140
Points
461
Shut the system down and when u hit the power button on the system start tapping the f8 key and select the option safe mode and when in safe mode go ahead and uninstall the driver from add and remove programs in control panel and restart the system and go in to the normal mode and download the latest version and install it
I KEEP GETTING A DE MESSAGE AFTER A FEW MINUTES
My washing machine is displaying an error code ... - Samsung
www.samsung.com/my/support/skp/faq/1033803
Samsung ElectronicsFeb 19, 2014 - ... your Samsung washing machine and the solution needed to resolve the .... If problem persists please call Customer Careline. *. dE. dE1. Ed.
tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
tip
SERVICE MODE AND ERROR CODES CHECK
Soyo monitor MT-NI-DYLM1998 "out of range."
Your windows 7 screen resolution is set too high and your display doesn't support it. There are 3 possible solutions to this problem:
1. Press F8 during startup and choose "Enable row-resolution video"
2. Press F8 during startup and choose "Safe mode" and change screen resolution there, then reboot.
3. You can always use another display (if you have one) to set screen resolution to lower value.
HOW TO ENABLE PIP ON SAMSUNG 530?
hello noni calipes,
To enable PIP on Samsung series 5 its easy.
But you should know Samsung spec first (read the manual book).
PIP can be enabled if :
1. Input must be higher or equal to componen. (Componen, PC , HDMI)
2. PIP only displayed inputs as the primary and RF and AV (SD) as secondary.
3. PIP on Samsung 530 can not swapped.
4. The higher inputs will displayed as primary.
If any questions , call samsung cervice center or you can read manual book.
I hope help you.
Thanks.
2answers
I have lost all of my text messages on my samsung galaxy phone. there is no history of any messages. I had an error report when trying to send a message saying something like "android messaging...
If you have a computer, you can recover deleted messages from Samsung via Gihosoft Android Data Recovery Free. It's a professional Android file recovery software. With it, you are able to recover deleted text messages, contacts, call logs, photos, music, videos, WhatsApp messages and Viber chat history from Samsung, Huawei, LG, HTC, Motorola, Google, Oneplus, Sony, Lenovo, ZTE as well as other Android devices easily. Next, I will introduce how to retrieve deleted messages on Samsung with Gihosoft Android Data Recovery.
Samsung SMS Recovery How to Recover Deleted Text Messages on Samsung
2helpful
2answers
Display driver r300
update the video driver
Top ATI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
