Brake light driver side not working ...checked and repalced bulb still not working fuse ok ..the otherside working fine..the car is 57 new shape renault clio..experation 16v 1.2
Did you try the passenger side brake bulb in the driver side socket (maybe the new lamp is bad)??
If it works, then the problem is either a bad ground connection / wire at / between chassis and the shell of brake lamp socket, or bad 12 volt wire at / between the common passenger 12 volt brake light wire in the harness to the center contact on the brake lamp socket.
My suggestion is if the brake lamp wire is ONLY for brakes - not the directional too, simply add a new wire spliced into the passenger side brake light wire and extend it to the brake light wire closest to the new socket that you recently installed on the driver side. Disconnect the vehicle brake wire from the new socket and wire nut it off or tape it up (so it can't short out if it somehow becomes energized again) and splice this new wire to the new socket.
check that bulb holder connector is rushed completely home.check if earth wire is secure to body should be close to the rear light cluster,also check the fuse maybe sided for brake lights so that if fuse blows you dont lose both brake lights
check where the wires go from the inside of the body to the out around the gromet. I did run into one that the wires rubbed. Also if the light are on the trunk lid check where they go through the trunk latch.
Troubleshooting Procedures - Read Completely Before Beginning (American Car) All Brake Lights Not Working
Check System Fuse: A fuse is used to protect the brake light circuit from amperage overload. If the fuse has failed it will not allow the electrical current to continue to the brake lights. To check the fuse, first locate the brake light system fuse in the fuse panel which is either under the dash or under the hood in the power distribution center. Connect the test light to a ground like an engine or dash bracket and turn the ignition key to the "on" position. Using the test light probe both sides of the fuse. If the test light illuminates on both sides the fuse is ok continue onto the next step. If one side of the fuse illuminates the fuse has failed and needs to be replaced. If the fuse fails as soon as it is replaced or when you apply the brake pedal the brake light electrical circuit is shorted to ground. Rarely a system short can occur, a car repair manual is needed to find the wiring schematic for the brake light circuit. Once the brake light wiring has been located inspect and repair as needed.
Check Brake Light Bulbs: All cars have three brake light bulbs that create the brake light illumination affect. If all of these brake light bulbs fail no brake light operation will occur. I know what you're thinking, you might say all three brake lights at once? But in reality one brake light went out at a time and you did not notice. People only tend to notice something when they almost run into the back of your car to help persuade them to inform you the brake lights aren't working. Remove any of the brake light bulbs to confirm the bulb is ok or burned. After the bulb has been removed inspect the filament and replace if failed. If the brake light bulbs are ok continue to the next step.
Checking the Brake Light Switch: A control switch is used to connect the brake light electrical circuit. This switch is located near the brake pedal lever. Basic switches have just two wires, power in and power out to the turn signal switch. Use a test light that is grounded and with the key in the "on" position test for power at one side (wire) of the switch, then press the brake pedal while testing the opposite side (wire). It should illuminate the test light, if electrical power is connected through the switch go to the next step. If no power is detected through the switch the brake light switch has failed and replacement is required. If your car is equipped with more than two wires integrated into the brake light switch a car repair manual is needed to locate the proper brake light circuit wiring.
I have a 2001 Ford F150, my brake lights dont work. Ive replaced the bulbs, checked the fuses,and the brake switch on side of the brake pedal was replaced. I still dont have any brake lights. My third brake light works fine, along with my running lights,flashers, blinkers.
These are Dual Function Bulbs. They control the Parking Lights and the Brake Lights. This Bulb is Burnt out on the Brake Coil inside the Bulb. I have actually seen Bulbs that were Bad But you could not Tell by jast looking at them. It should be fine with a New Bulb. Please Rate My Response! Thanks!
