If the compressor is running and it's not cooling it sounds like you have a leak in the sealed system.you can remove the inside back wall of the freezer and look at the evap coil.if there's ice just on top or ice pattern isn't covering the whole coil then you have a freeon leak in the sealed system.if the compressor is hot it sounds like it's running,i did find the compressor hot,changed out the start device and it did run again but the compressor was clicking,if you're positive the compressor is running most likely you have a leak in the system and it would be to much to fix.part number for the start device is 8201786 and it's around 55 dollars.
