SOURCE: DWL-122 driver not installing, device not recognized
The wireless adapter will not show on the My Computer. Try to right click the My Computer icon go to properties, then go to Hardware tab then click the device manager button, click the + sign beside the Network Adapters category and check if you have the adapter listed there. If the adapter is listed check if the driver is installed properly by going to the properties of the card.
SOURCE: same
You may want to check your power supply and make sure that it meets the requirements for your system, a lack of sufficient power can ofter cause a computer to restart or freeze.
Your card uses 15 dBm ± 2dB
http://www.newegg.com/product/product.aspx?item=N82E16833127145
If this is a laptop, make sure to plug in the machine as power is limited while your laptop is unplugged.
If you've done all the math and the power supply isn't the problem, you may wish to try your card in another pc. If the card doesn't take in either machine, you should contact d-link and ask for a replacement.
http://www.dlink.com/support/
SOURCE: can't install a new d-link dwa-552 wireless
This list 2 methods of installing it. Says if the first one doesn't work do the 2nd one.
http://www.dlink.com/support/faq/default.aspx?question=dwa-552
SOURCE: D Lin Air Plus G Utility will not open
What is the operating system on the computer ?
You said that you installed the drivers on the computer for the adapter.
If the OS is Win XP or VISTA then you don't need the utility to connect to the network.
Windows has it's own utility to connect to the network.
go to start = go to control panel = go to network connection = you will see wireless network connection
if you right click and go to view available wireless network.
First check the Device Manager.
Click Here for more info about the networking
SOURCE: wireless adapter not found please plug-in the DWA-120
After uninstalling it completely from the computer. When you plug in the adapter alone. You must get the "Found New Hardware" wizard. And nothing else apart from this. Only then it is correct. If nothing comes up at all, the device is dead or your version of USB might USB 1.0 or USB 1.1 which at times has issues. But if you see that wizard coming up, unplug the adapter and insert CD and run setup and walk through it.
Anyway, i ll recommend that you try this adapter on other NEW computer(laptop or desktop), just to check.
I feel that this adapter would work on a new computer, maybe your computer's hardware specifications are old to support this device.
