Expert
- Posted on Jan 22, 2011
Re: Theres no power getting to microwave
Pl. check mains supply and the plug of the microwave if every thing o.k check the fuse provided inside the oven,if o.k then the problem in the control panel,check the panel by replacing the same .
Open the top cover of oven and check the AC fuse that is positioned just after the mains cord inside the oven,if o.k then the problem is with power supply given in the main PCB assembly,if you are technical person check the Power supply components for defect or consult a technical person.
