Targus 4PORT USB 20 TRAVEL HUB  ACH7405US ACH7405US Logo
Posted on Jan 22, 2011
I plug in the 4 port usb targus and it doesnt respond
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Feb 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
6653
Points
34
Sometimes you have to plug a usb into these to get them to respond if this does not work try plugging it into another USB port. If this does not work than look at the wires they may have come unattached
Targus pa055 manual
These are just plug and play. No instructions required.
Targus 4-Port not working
First off hubs don't support a lot of power hungry devices so you should be able to buy an optional power adapter for the hub on targus' site.
Second if your computer doesn't have any usb 3 ports then the hub will only operate at usb 2 speeds.
Your probably overloading the hub. Buy the power adapter.
1helpful
I bought a 4 port usb hub targus and it doesn't work with my windows 7
Right click on my computer or the icon for my computer and select manage then open device manager and see what it says in there then up top select check for hardware changes icon, this should look for and install the hub
2answers
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
13helpful
8answers
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Targus Travel USB 2.0 4-Port Hub with Notebook Light
I'm sorry to tell you your hub cannot be fixed. I have one just like it and have taken these things apart and repaired simple factory errors as loose wires and the such.
You should get yourself another Targus brand USB hub. They are good and quite reliable
Regards,
Worldvet.
Top Targus Computers & Internet Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
