SOURCE: volume controls
Just sorted it. The solution is a touch long winded but it worked for me.
Sorry for the delay in replying but i THINK have have the solution which I got of the Saitek forums.
I have had the same problem with VOLUME controls on two MS keyboards and a logitech, this worked a treat.
So what do you need to do?
FIRSTLY check Control Panel->Administative tools->Component services and click "Services (local)", on the RHS look for "HID input service" under STATUS it should say STARTED, if it DOES im not 100% if this will help but try anyway. If it DOESN'T this should work.
Go to START->RUN and type REGEDIT and navigate your way to the following:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HidServ\Parameters
If there is a file called "ServiceDll" delete it (make a copy obviously and stick it on your desktop or something). Right click in the RHS of the page and create a NEW->Expandable String Value.
Call it "ServiceDll" (exactly as typed here without quotes), and make the value read "%SystemRoot%\System32\hidserv.dll" (without quotes). Now exit out of Reg edit and go back to Control Panel->Administative tools->Component services. Next to HID input service right click in the gap under STATUS and press START. Close properly and your volume should now work.
Good luck.
SOURCE: microsoft wireless desktop 1000 keyboard problem
not being a smart alek but did you try changing the batteries? and if you did did you try a new set?
SOURCE: Microsoft Wireless Keyboard 1000 v 1.0 volume keys not working
On 32-bit machines: Use the windows search feature to find "hidserv.dll." Once located, copy the file and paste it into the %systemroot%\system32\ directory. Open the "Run" dialog box by keying the windows + R. Type "services.msc" and hit enter. Locate the HID Input Service. Right click and click "start." This should solve the issue!!
SOURCE: microsoft wireless keyboard 700 v2.0 media keys
Media keys are reprogrammable. Use the CD that came with the keyboard and refer to the user manual for instructions.
You may also contact the tech support for your keyboard to assist you.
Have a great day!
SOURCE: Keyboard map for Microsoft Wireless Optical Desktop Pro
when i go into keyboard properties there is no 'key settings' option
