SOURCE: power supply replacement for emachine et1641-02w
i just bought a emachines as well and i noticed when purchasing a new video card that it required a 450 watt power supply, so i went to check and see how much the one i had just purchased had and of course it was 250! that is soooo low, anywho, what i am sayin is if you think that you are going to add any drives or a after market vid card then yes you need to replace the powersupply in ur emachines with at least a 500 watt, they are like 50 to 100 dollars at tigerdirect
SOURCE: i add downloaded messenger to my emachines ET1641-02w
Registry looks to be corrupted.
As you boot the computer, press F8. You'll get the boot menu. Select 'Safe Mode with Networking'. Now the computer should be able to get into Safe Mode.
Get on to internet, Start a free registry scan from www.registryfix.com
If this fails, you may need the Windows Installation Disk to fix it.
SOURCE: emachines ET1641-02W constantly freezes because of Norton360?
could be the website your going to
doubt it's your hard drive unless it does it all the time
also do a virus scan
SOURCE: Emachine W3623...(problems)
I had same problem,and what I did was to clean all around the fan and the aluminum air cooler ontop of the prccessor.After that it worked smooth till it got dirty again.Have you tried this.letm
SOURCE: emachine wont start
How many hours you working you computer? 1 or 2 or 3 hours?
if you working 2 or 3 or 1 then automaticaly shutdown then, when you push the power button the cpu fan is working but in few minuts shutdown again,.... check you cfu pan maybe this over heting only.. try to make cold the computer then start again if dos't work.. check the power connnection in the motherboad........
