HI!
My washer, mentioned above has stopped working. It filled up with a normal sized load and just stopped working. The unit is getting power, however nothing is occuring. I moved the clothes around thinking maybe it was off balance and tried to restart...nothing.
The MOD # is 11024632300 and the serial # is CR3872120.
I cannot get the water to drain, no power seems to be getting to it and the unit is less than three years old. ANY help you could provide would be appreciated!
Check to make sure the lid switch is closing when you close the lid. When you open and close the lid you should here a click similar to a wall light switch.
Also check the lid to make sure the tab has not broken off that actuates the lid switch, your model may not have a tab on the lid.
ask more questions is lid switch is functioning,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
I have a similar problem with my washer. I put in a load of clothes and went on to do other chores. When I came back, it had only filled up with water, wouldn't agitate, spin or drain. I checked the cycle switch, the door switch, and nothing. I've checked the fuse box, and finally ended up taking all clothing out and checked to see if drain hose was clogged. It was clear.
Other than that, I haven't tried anything else unless I had some documentation on it.
