Bloomfield 8543 Coffee Maker Logo
Posted on Jan 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Bloomfield Koffee King coffee maker that won't heat up. I checked the heating element and it's ok. What else could it be? thank you Robert
Anonymous
Level 2:
New Friend:
  • Expert 91 Answers
  • Posted on Feb 09, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
91
Questions
0
Helped
27589
Points
143
Check the hi-limit or the thermostat.
Making loud popping sounds
Sounds like the heating element is bad and may cause a popping noise.Also a loose or shorted wire.
THE MR. COFFEE COMMERCIAL COFFEE BREWER MODEL MRCTB. IT DOESN'T HAVE ANY LABEL. MY QUESTION IS JUST NEED TO KNOW IF I CAN USE THIS IN 110 V OR 220 V. SINCE IT IS COMMERCIAL.
Hope you can help. Water runs though pot but the water is not hot whatsoever. Heating element burned out?
Commercial Brewer 8543
My water doesn't get hot
you either have a bad thermostat, a wire off, or bad heating element. the heating element will burn out quickly if the pot is plugged in with no water, or if left unused for long periods of time. the water evaporates, and the element burns out. best thing is to remove top, and take a look.
2helpful
Our church received a Bloomfield Koffee King model 8571 and no instructions on how to set up and use the coffee machine.
Hi, Get 2 pots place one under the spray head with the filter cone in....now fill the other coffee pot and start to pour water through the lid top front...keep pouring water through (about two and a half pots) until water starts to pour through the cone....now the tank is full plug her in and turn on the power switch at the back and also the front if there is one....place filter in cone..put coffee in filter...pot on burner...wait about 25 minutes until water in tank is hot...when light on front comes on pour another pot of cold water through the top and you will get a pot of hot coffee in bottom....I also think this machine can be hard wired into water main....get plummer to hook up...follow same procedure but instead of pouring water through top for coffee..hit brew switch. if it poors too much of too little you will find a timer in the machine you can adjust to allow more or less water...hope this helps.
1helpful
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
2answers
TRY REPLACING THE SEALS IT WORKED FOR ME
Bloomfield 8572 Leaking
I just repaired my Bloomfield 8543 unit. I removed the top, by first removing the top rear 2 screws and unplugging the 2 heating element wires under it. Then mark all the wires that go to everything, (it is only a few) remove the center screw that holds the water tank lid brace down, slid the brace to one side (the groove on one side is longer) and remove the brace. (My brace was bent.) Then lift the lid (the heating elements will come with it) and clean the gasket. I went as far as to remove the tank, clean that as well as all the tubes. I tightened everything down and it worked perfectly again. Good luck, ken
Top Bloomfield Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Bloomfield Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
