To remove the bulb you will have to remove the cabinet of
the microwave to replace the bulb and its mounted inside next to the tube area
by two screws. The lamp is inside the top. ------------- Now to disassemble the body cabinet, you will require the
disassembly diagram. To get disassembly diagram please click on this link below:
--- With the help of this disassembly diagram you will take apart the cabinet,
now to remove the lamp you will require internal parts disassembly and location
of lamp. To see where the lamp is located. Click this link directly and in the
diagram part number 2 is lamp:---- This disassembly diagram will help you to remove the bulb. To order new bulb, please click on the link below: --- http://www.repairclinic.com/PartDetail/Lighting-Component/903746 This will help. Thanks. Helpmech.
After you click the link directly the link will get open and you will see the diagram.On the upper right corner there is print option.To print the diagram and it prints.But may be your printer must not be connected to pc or the exact printer is not selected so it must not be printing.Otherwise it actually prints.-------- Try resetting your printer and reconnecting the printer.This will help.Thanks.Helpmech.
Thanks Raj!!!
I can't seem to print the diagrams....is that typical??
