I do not have the manual for the opener. I went by the instructions on the lid of the outside Key Pad to change the PIN from the old one to a new one. The problem is, it did not cancel out the old one, now both numbers work to open and close the door...
How do I get rid of the old number?
Thank you,
OCBurruz
Here's a link for chamberlain garage door opener manuals.
http://homeappliance.manualsonline.com/manuals/mfg/chamberlain/chamberlain_garage_door_opener_product_list.html?s=gg314159
You need to reprogram the system please follow the instruction:
To re-set your code, please follow the steps outlined below:
1) Unplug your garage door opener from the electrical outlet.
2) Open the cover on your inside wall console. You should see a 9 Volt battery and an adjacent PROGRAM/OPERATEswitch. Slide the switch to PROGRAM.
3) Enter your new 4-digit code into the keypad outside.
4) Slide the switch back to OPERATE and replace the console cover.
5) Plug the garage door opener back in to the electrical outlet.
6) Test the new 4-digit code. (If the keypad does not illuminate, replace the 9 Volt battery)
IF you want more information you can click on this link:
http://www.chamberlain-diy.com/diy04/faq_view/0,1341,uid-f2l9cWRnbGtnaw==_942-id-9,00.html
Good luck....
Can you please provide the exact model number of your Security device...
Thanks
ok... got it " LiftMaster Professional Model # 2575". Is this correct...?
Kindly wait & I will post back here again...
Regards,
micro
This is the link for the manual;
Hope this helps... Please kindly rate my solution, will yah...?
Regards,
micro
