Plug an Ethernet cable into the "Ethernet" or "To Computer" port located on the back of your Internet modem. Plug the other end of the Ethernet cable into the WAN (Wide Area Network) port located on the back of the Linksys router. The WAN port is segregated from the four LAN (Local Area Network) ports also located on the back of the router. Connect the power adapter plug into the power port located on the back of the Linksys router and then connect the other end into a power outlet. This powers the router on. It does not have a power switch. Plug an Ethernet cable into one of the LAN ports located on the back of the router and then plug the other end of the cable into the Ethernet port for the computer you want to tether to the router. If you want all computers to connect wirelessly, skip this step. If you have additional computers that you want hard-wired, repeat this step for each computer. Again, you can tether four computers to one router. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Read more: How to Set Up Linksys ' eHow.com http://www.ehow.com/how_6949829_set-up-linksys.html#ixzz1BdHrojjx
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Hi ! Click the link below for proper cable connections in setting up your wireless network. http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx Thanks. Mongkey "Understanding explains better..."
