Paslode air nailer
With the Paslode cordless tools there are a couple of things that will prevent the tools from firing; a jam at the nose of the tool, a dirty combustion system and slack in the spring that pushes the finish nails forward.
First, remove the battery to prevent inadvertant firing, then check to see if you've had two finish nails driven thru the head. Remove any finish nails in the tool. Now lift the nose latch up to release the drive head mechanism. Once you have that up, you can look and see if there are any nails jammed in between the guide and the driving ram. You can push up the ram with a flat bladed screwdriver to make it easier to get the jammed nails out.
IF, the jam can't be removed easily with a pair of needle nose pliers, by pulling the nails down and out away from the tool body, you'll have to take the front nose of the tool apart (not normally needed, except in really severe jams).
If the tool isn't jammed, try putting in a new full strip of nails and pull back on the spring about a inch or two and let it go, so it'll push the nail strips all thw way forward, which will make sure the nailer isn't being locked out by the "last nail" safety switch.
Lastly, you need to clean the tool, as they don't work reliably when dirty, so follow the cleaning instructions that Paslode provides with the tool (they're tool involved and lengthy to type here)
Some other things you can check are to make sure the fuel cell cap is properly seated on the fuel cell, by pushing it all way on both sides till it clicks in place. Also, you can check for fuel flow by briefly depressing the fuel cell against a flat surface (no open flames nearby!!) to see if you're getting any fuel squirting out of the cell, as sometimes that helps to get the fuel flowing.
It also needs to be warm enough to operate. These tools don't do well when subjected to very cold temps. I always keep the batteries and fuel cells inside when the temps are below 40 degrees.
I've found that the Paslode finish nailers jam frequently due to the plastic carrier that holds the nails together, so I don't bother trying to use any small nail strips, (2-6 nails left) as they tend to cause problems. It's more productive to just use full to 1/3 strips of nails and avoid the possibility of jamming that comes with trying to load in some 2-6 nail strips.
Hope you find this Very Helpful and best regards!
