GoVideo DV2150 DVD Player/VCR Logo
Posted on Jan 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I lost my remote and cant play DVD's without it. The play button on the front panel will not play movies. Cant use my Time Warner Cable univeral either.
Sean Burke
Level 2:
New Friend:
  • Expert 161 Answers
  • Posted on Jan 20, 2011
Sean Burke
Expert
Level 2:
New Friend:
Answers
161
Questions
0
Helped
58787
Points
458
I have found a remote control website where an original or off-brand remote can be purchased:
http://remotes.com/store/go_video/dv2150.html
2answers
Lost remote control of my lg dp122 and now i dont know if i can play movies
get a logitect universal remote and set it up to the dvd player.
I know what you are asking and I don't think you will be able to move or select sub menus on movies without a remote.
or buy another remote
http://www.ebay.com.au/itm/like/261378869015?hlpht=true&ops=true&viphx=1&lpid=94
NEED TO EJECT MY DVD USING THE TIME WARNER UNIVERSAL CONTROL. WHICH BUTTON IS IT?
Universal Remote codes for Blu-ray Players - AVS Forum ' Home ...
www.avsforum.com/...control.../1297068-universal-remote-codes-blu-ra...
Dec 10, 2010 - 12 posts - ‎7 authors
Brand new Sony bdp-bx59 Blu ray player with a Rogers Atlas PVR remote, Model 1056B01 ... A button, my Samsung DVD/VCR remote's Power button in there on the ... it just means the machine you are trying to control either came out after .... I have the same Blu Ray and Time Warner remote as you do.
Eject key unavailable on sony blu ray bdp-s3200 - Fixya
www.fixya.com/.../t24026716-eject_key_unavailable_sony_blu_ray_bd...
Apr 6, 2014 - eject key unavailable on sony blu ray bdp-s3200 disk tray wont open -Sony BDP-S3200 ... Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 4 Answers .... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? ... Sony BDP-S300 tray open while updating, stuck here.
How can I fix my Sony Blu-Ray player BDP-S3200 with the ...
www.fixya.com/.../t24578583-fix_sony_blu_ray_player_bdp_s3200_eje...
Jul 27, 2010 - Question about Sony BDP-S3200 blu-ray/DVD player with WiFi. 1 Answer .... SOURCE: Sony BDP-S300 won't play any Blu Ray discs. Sounds ... How do I program a Phillips (time Warner)RC122 to run a sony BDP-S3200 dvd? Dec 28 ...My player cant eject disc; it say '' eject key is not available this time''.
Remote codes - Comcast Help and Support Forums
I need a remote code for sv2000 Tv,dvd combo for a Time Warner remote control
Check this link to download the user manual to your remote control. It has all details you want.
3helpful
How to get unit to play without remote
You can probably use the front panel buttons (STOP PLAY OPEN/CLOSE etc) manually, the only thing you cannot do without the remote is access certain DVD menus, including subtitles/language/special features etc. You can always obtain and use a universal remote for basic menu functions later on if necessary.
To play a DVD movie without the remote, simply load your preferred disc, wait for the player to finish reading its contents, then to skip copyright warnings and/or the 'play movie' menu screen, press STOP, then PLAY, or simply press PLAY button where 'play movie' (or whatever function) is highlighted in the menu. These buttons should be on the front of the main unit. Doing this should encourage the player to detect the appropriate title (the movie) and play it (basic playback operation may not be possible with some DVD releases due to the numerous interactive menus and title pages, such as film trailers).
If basic manual operation is not completely possible with some DVD titles, consider a universal remote for your player if you have either lost your original, or the player was purchased/received without one. Such remotes are relatively inexpensive to purchase, and are available just about everywhere.
1helpful
Need 3 digit code for controlling sony rdr-gx7 dvd recorder with my time warner cable remote.
This is a common problem for the Sony RDR-GX7 dvd recorder.
It seems to occur with various remotes (DirectTV, Bell ExpressVu or in your case, the time warner cable remote).
In most cases, the problem can be solved by using a different remote frequency from the system menu as follows:
Insert a dvd and make sure it is not playing (stopped).
Enter the System Menu then / Setup / Options / Command Mode (this can be done from the access panel on the front of the unit). There are 3 possible values, (DVD1, 2 or 3), try changing it.
Then enter one of the suggested codes for your Warner remote (in my case, for Bell ExpressVu I selected the DVD1 command mode
and I used 883 as the 3-digit code. The up and down arrows are not functional with this code but I bypass this problem by entering the menu item number. Good luck!
1helpful
Programming dvd player
It sounds like you may not be on the correct input selection on the tv to watch the dvd player. Ther are probably three or four inputs to choose from on your tv. whichever input you hooked the dvd player into on the tv is the same imput you have select using the tv's remote control in order to watch movies on the dvd player.
2answers
Need remote control code forphilips hts8100 to program univ-remot
I have a brand new one!!! I can list it on ebay very cheap. You can e-mail me at [email protected].
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
