To clean your laptop's keyboard you have to look under your laptop, you can see like keyboard icons with some scews, so, open them, they will let yout to remove your keyboard.
So now your can remove just your keyboard slowly for some connectors on the motherboard then clean it with a tooth brush.
You can only clean your keyboard with a toothbrush without rmoving it,
Try to remove the space bar key and clean under it.
Try to hard press the space bar for about 5 times, it can release the pusher under the key.
it some liquid was spilt on it you have to remove the keyboard and clean the plastic under ther keyboard.
Good luck
Testimonial: "Thank You so much!!!"
It could be as simple as something stuck under the key . turn laptop upside down and lightly tap to dislodge debris. if you feel comfortable remove the key with unit off and clean.
