Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Posted on Jul 16, 2008
Keypad outside not working Properly
We have a 2 year old Sears Craftsman Liftmaster and now the keypad outside will not work. The vehicle door openers work, the opener on the wall inside the garage works and the outside keypad will close the door, but will not open it from the outside?
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Feb 10, 2009
Anonymous
Contributor
Level 1:
Answers
30
Questions
Helped
23709
Points
81
Have you replaced the battery in your keypad? That should take care of the trick.
  • Anonymous Feb 10, 2009
    Have you replaced the battery in your keypad? That should take care of the trick. The reason it works to close it is because there less traffic is the way when teh door is closed it need to have more power.
Hi... I have a Sears Craftsman Garage door Opener Model# 139.53600 Outside garage door keypad which is hard wired (electric) isn't working. However the inside keypad and the car transmitter are both...
A wireless keypad will not work with your opener. Your opener is pretty old and the new models are much safer. You might consider replacing the entire thing.
Garage Door Opener Keypad I have an older Sears CRAFTSMAN Garage door opener and am trying to find a Keypad (that is afixed to the outside of the garage). that can operate the door. I have a remote (2...
Call around to the Chamberlain dealers in the yellow pages. They might have one in stock. The part number is 66LM. They are expensive though. $55.00. You might consider replacing that old opener you have.
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: outside keypad will not open garage door at all bu...
The inside button is hard wired. The keypad is a small radio transmitter. If the battery in the keypad is good and it doesn't work when you put in the code it has probably just quit.
Nnew Sears garage door opener - old keypad
Yes,buy the new keypad in the safe side.Probally have new Inferred signal codes by the new remote might work with the old keypad.
Keypad and remote will not open door
Did the remote and keypad work before you changed the battery? Changing the battery in the keypad should not affect the remote.
Cant get wireless Keypad to Link to new Garage Door Opener
The radio frequency has changed and the old keypad will not work with the new opener.
Keypad garage door opener will not operate
what keypad are you using with new opener? Frequency has changed. can't use old one. you probably never needed to change things; just needed to follow proper coding procedures.
1helpful
Clicker garage door keypad works inconsistently
no relation. did you plug rpm sensor and logic board connectors on well.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
