What you are seeing is a low tire pressure light and it will illuminate when the air pressure in any of the tires is above or below the factory recommended pressure. It can also illuminate when there is a sensor that has gone bad or is defective, this usually happens after you have had new tires installed, if the technician damaged one. I would recommend that you first look in the drivers side door jam of the vehicle to see what the recommended tire pressure is and then check all of your tires to see if the pressure incorrect, and if so then fill or let air out of the tire to the recommended psi.After you have done this, drive the vehicle and the light will automatically turn off. If this does not work, then I would recommend taking the vehicle to Toyota and they will be able to pin point which TPS (tire pressure sensor) is not reading correctly and you can then have it replaced. I hope that you have found this information useful as that is my goal.
