ECM (Error Correction Mode)
The Error Correction Mode (ECM) is a way for the fax machine to check the integrity of a fax transmission while it is in progress. ECM transmissions are possible only between machines that both have the ECM feature. If they do, you may send and receive fax messages that are continuously checked for their
integrity.
Sufficient memory must be available in your FAX/MFC for this feature to work.ECM (Error Correction Mode) Detects errors during fax transmission and resends the page(s) that had an error.
If you have Call Waiting, RingMaster, Voice Mail, an answering machine, alarm system or any other
custom feature on a single phone line with your fax machine, it may create a problem sending or
receiving fax data.
For Example:
Your Brother machine handles the Caller ID and Call Waiting/Caller ID subscriber services.
However, if you subscribe to only Call Waiting or some other custom service and its signal comes
through the line while your machine is sending or receiving a fax, the signal can temporarily interrupt
or disrupt the fax data. Brother's ECM feature should help overcome this problem. This condition
is related to the telephone system industry and is common to all devices that send and receive
information on a single, shared line with custom features. If avoiding a slight interruption is crucial
to your business, a separate line with no custom features is recommended.
ACTIVITY REPORT
The FAX is factoryset to automatically print an ACTIVITY REPORT after every 20
transactions. If you want to print an ACTIVITY REPORT before it is automatically
printed, follow this procedure:
Transactions in an ACTIVITY REPORT are listed chronologically.
1 Press Function.
2 Press Report.
3 Press OK.
• The FAX prints an ACTIVITY
REPORT.
• If you prefer the FAX not to print an ACTIVITY REPORT after every 20 transactions,
disable the ACTIVITY REPORT setting ( p. 145).
• Please note that only one transaction number (TX/RX NO.) is assigned when you send
a document to several fax numbers in one operation.
ACTIVITY REPORT
PRINTING REPORT
27/12 2002 15:00 FAX 123 4567 CANON 001
ACTIVITY REPORT
ST. TIME CONNECTION TEL CONNECTION ID RESULT
* 27/12 13:43 905 795 1111 Canon CANADA 5001 AUTO RX ECM 1 OK 00'33
* 27/12 13:45 905 795 1111 Canon CANADA 0001 POLLING RX ECM 0 OK 00'00
0 STOP
* 27/12 13:51 03 3758 2111 Canon TOKYO 0002 B'CAST ECM 3 OK 01'18
* 27/12 13:53 2 887 0166 Canon AUSTRALIA 0002 B'CAST ECM 3 OK 01'18
* 27/12 14:10 905 795 1111 Canon CANADA 5002 AUTO RX ECM 1 OK 00'18
* 27/12 14:16 2 887 0166 Canon AUSTRALIA 5003 AUTO RX ECM 4 OK 03'59
* 27/12 14:27 20 545 8545 Canon EUROPA 0003 DELAYED TX ECM 1 OK 01'20
27/12 14:30 20 545 8545 Canon EUROPA 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:31 03 3758 2111 Canon TOKYO 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:57 2 887 0166 Canon AUSTRALIA 0005 TRANSMIT ECM 3 OK 01'25
0 STOP
27/12 14:59 1 432 2060 CANON OPTICS 0006 TRANSMIT 0 OK 00'01
0 #018
go to this site to download manual (see page 11-3)
http://files.canon-europe.com/files/soft30110/manual/FAX_L220_L295_UG_ENG.pdf
