SOURCE: air compressor slow to build air pressure.
you might need to checktosee if the filter is blocked or dirty were the air intake is just like a car dirt can build up there.
SOURCE: air compressor - pressure problem
'When the machine is shut off, disconnect the discharge line out of the head of the compressor. If air releases, replace discharge check valve in tank.
SOURCE: Air compressor won't build pressure
If this unit has what appears to be a pipe with fins on it , you may have a ruptured inter-cooler which will be leaking where you stated.
SOURCE: craftsman 3 gal air compressor - no air presssure
Check the head gasket. Mine just did the same thing. Mine was blown between the two chambers on top. It's very thin right there. I went to the auto parts store and bought some gasket and made my own for about $6. It's up a working great...finally. BTW the gasket kit is on back order right now at Sear's parts website. It appears we aren't the only ones with the problem!
