If this alarm system makes it you engine won't start, it is a little more complicated but if all it does is make noise then open the door, open the hood, find the alarm horn (it will be the one making all the noise) and cut the wires. They can be easily spliced back together once you get a new remote.
SOURCE: I lost the remote to
When you use the key to start the car the alarm will disarm. You can now purchase replacement key fob's from Autozone. They are easy to program and cheaper than the dealer. I would recommend checking ebay as well for a replacement fob.
SOURCE: i lost my keys for toyota celica 1996 year,i had
Look under the steering column ,now normally on an after market alarm installation ther should be bunsh on wire tied up with plastic zip-ties --looks like a mess , and in that a mess look for a square relay about 1" sq. Unplug that. That will isolate the alarm system.Good Luck
