Tips on cooking rice:
You estimate first how many rice you are cooking then follows how many water you will be needing to cook it.
In an average, 1 cup of rice per person (depending on the persons appetite) = 2 cups of water. Rinse first the rice about 2 - 3 times to remove unwanted stuffs then start pouring and measuring the water.
Note:
1 cup rice = 2 cups water (common ratio), but there are also type of rice that requires more water or less water. You can adjust next time the water depending on the result. If the rice is a little bit hard then add more water the next time you cook. If the result is too soft then minus the water.
Hope you can cook now a perfect rice! Bon appetite!
Don't forget to rate me and thank you for using FixYa!
regards,
John
SOURCE: Overboiling
On this rice cooker to make a perfect pot without overboiling....Use 2 cups of rice and 4 cups of water, When it starts to boil life the lid ONCE and stir and then put the lid back on pressing down to make a seal, The water should not boil over if you follow these instructions, I just made a pot :).....Oh and use the same measuring cup for the rice and the water, Just remeber....One cup of rice = two cups of water!
SOURCE: Amount of Rice
The Japanese measuring cup size of 200 ml works fine for my Hitachi RD-5083 and likely will work for most rice cookers. The standard US cup is 237 ml.
SOURCE: Wolfgang Puck 7 cup rice cooker instruction manual missing
Here the standard manual : WOLFGANG
However you can read and print recipes online from their website , click below:
Rice Cooker Recipes Cookbook : Recipezaar
Rice Cooker Creations Cookbook
SOURCE: Measurements for Rice
Most of my experience with the rice cookers is that they require a japanese rice Cup which is different than the japanese regular cup. makes a whole lot of not sense but i found a replacement cup at one of the local Japanese Markets if you had to you could use regular measuring cup and use the 160ml for your measure. also the cup has a "Inomata" on it so maybe the web can help you
Eat lots of Rice
SOURCE: Need manual English for Elite 3 cup rice cooker
The Elite is made by Maximatic and you can download their owner's manual at http://www.maxi-matic.com/download_manual.php?filename=ERC003ST_008ST_010ST_015ST_manual.pdf
