SOURCE: i have a toshiba satelite laptop model a505-s6005
In case these components are just plastic covers you will not have any problem but beware of the dust that may come into the laptop. If these components are electronics, I'm sorry to said that you will have various problems, depending on the components.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
SOURCE: HI, I need the procedure for replacing the screen
Turn the computer off.
Disconnect the AC power.
Then, since you need to ask "how" to do it, I strongly recommend that you take the computer to a qualified technician, for _professional_ repair.
What you're wanting to do is _very_ complicated, and you could really "break" things, as you try to disassemble your computer, without breaking any wires that connect the motherboard to the LCD screen.
SOURCE: Toshiba Satellite A505-S6005. I cannot
First off have you tried doing a system restore? That is the first thing I would try. If your unable to restore. I would back up any valuable data and reinstall windows with either a copy of windows or if there is a recovery partition on the hard drive. If you need further assistance please let me know.
Thank you,
Lee
SOURCE: toshiba satellite A505 S6005
Head over to Toshiba's support site for your laptop here. Switch All Categories to Camera and download the web camera application. This contains the web cam driver.
SOURCE: 2 usb ports on right
Hello geniet1:
If the USB ports are loose, then the computer is going to have to be disassembled for repair.You should have Toshiba, or a Toshiba authorized service center fix it. If I remember correctly,all you have to do with Toshiba laptops is just drop them off at UPS for repair.UPS sends them to Toshiba for free, and Toshiba returns the repaired laptop to you.
