Now it looks like you have a problem here. Different cameras/chargers have different polarities. If you try to charge with wrong chargers then there is a possibility of the batteries getting damaged or sometimes may even explode, so be very careful in future. Some times the power control board can also get damaged and may require repairs. At this juncture you can try hoping for the best to replace the batteries. On many occasions this has solved the problem. Regards. PLZ. don't forget to rate my solution.
Bottom of the camera, toward the end with all the controls. Take a look at the second image in http://www.kodak.com/global/en/service/publications/urg00836toc.jhtml?pq-path=12650/12671
The only change you can make in the shutter speed is to choose how long you want the shutter to stay open for long time exposures. If you want to make changes to things like shutter, aperture, etc. you need a much more expensive camera or even a DSLR.
Your problem may be due to corrosion on the
battery contacts inside the camera
which can prevent the full power of the batteries from flowing into the
camera. Try this free fix before you do anything else: remove the
batteries and wipe the camera contacts firmly with
a dry cloth (heavy corrosion may require cleaning with a wire brush,
steel wool, or sandpaper). Remove any residue that may have fallen
into the battery compartment during cleaning, then wipe both ends of
the batteries and place them back in the camera. This cleaning clears
the problem about 90% of the time. If it doesn't work for you, the camera may have
a problem that requires professional repair.
That actually sounds like normal operation. The screen is set to automatically power down to save the battery. This can usually be adjusted in the setup menu to stay on for a specified time or constantly. When it powers down, a press of any button usually brings it back on.
