Dryers Logo
Anonymous Posted on Feb 01, 2011
Kenmore Electric Dryer Model 110.69902890 tumbles and blows air. Does not get hot. Unit hook up 120/240VAC 3 or 4 wire, now a 3 wire hook up ( third wire green tied to chasis ground. Heating element continuity good. Must this unit use a 240AC hookup? Please advise. Thank you
Anonymous
Level 3:
President:
  • Master 1,554 Answers
  • Posted on Feb 01, 2011
Anonymous
Master
Level 3:
President:
Answers
1554
Questions
0
Helped
611857
Points
4917
The dryer operates both on 120VAC and 240VAC. The motor and the controls are hooked up on 120VAC whereas the heating circuit is on 240VAC.
The problem here is likely with the thermal cut-off and the high-limit thermostat located on the heater housing. Disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the hex-head screw from the Kenmore Electric Dryer Model 110.69902890 - jahn27_87.jpg and remove the shield.
Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-ofKenmore Electric Dryer Model 110.69902890 - jahn27_88.jpger terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
Let us know if you need further advice. Please make sure you accept the solution should you find it helpful or informative. Accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 • Dryers
3helpful
2answers
Kenmore HE Dryer not blowing hot air
I have a gas kenmore dryer... the drum runs- it blows air and for just a few minutes warm air but after a few minutes the air is cold. I have cleaned the vent checked it good. I didn't see the fuse on the back I have the bottom latch open and see several wires that can be disconnected; snap together.
Dryer doesn't "dry"... eletrician/husband inspected the unit- circuits working for heating element. Belt intact. Dryer tumbles, but doesn't get HOT. Thermostat?
It depends on if the unit is electric or gas. Both will have a thermal fuse if the venting is restricted the fuse will blow if its a whirlpool or kenmore brand. The thermal fuse is white and will be either located on the back or in the front by the blower housing. If the lint screen is located in the top the fuse will be in the back. Have your husband take a look at the schematic he should be able to find the fuse. Also i know he probalby checked this but the unit needs 240v for the unit to heat if its electric but the motor will still run with 120v. Make and model would allow me to help much more.
1helpful
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 • Dryers
Dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
2helpful
Kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
2answers
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Top Dryers Experts
john h
