Samsung Galaxy S GTI9000 Smartphone Logo
Posted on Jan 19, 2011
My Samsung Galaxy s GT- i9000 keeps turning off its wifi it also says unable to scan networks
  • Anonymous Mar 25, 2014
    Samsung galaxy keeps turning on and off
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1032
Points
7
My wifi keeps turning it's self off?
When I go to settings and hit Wi-Fi, my networks do not appear. Have no scanning abilities
Samsung Galaxy S4: WiFi not scanning for networks:
Hello:
Try these troubleshooting tips:
1. If this is happening at home, it could be your network setup is having issues, turn off your router/modem, wait 2 minutes, and then turn the router back on.. wait for the router to connect and then try again..
OR
2. Go to:
Settings > WiFi > (remove your network & then re-add it, don't forget you need your WiFi password in order to log back in)
OR
3. Go to:
Settings > Connections (Network Connections) > More Networks > turn on Airplane Mode > wait a few seconds and then turn off Airplane Mode
OR
4. Go to:
Settings > My Device > Turn Power Saving Mode Off
S4 wifi will not scan for networks
Hello:
OR
2. Go to:
OR
3. Go to:
OR
4. Go to:
3helpful
My wifi keeps disconnecting and have to restart phone to reconnect, but only lasts for maybe an hour
Samsung Galaxy S 4G Smartphone: WiFi disconnects (have to restart phone to reconnect, does not scan for WiFi connections):
Hello. It could be that your "Auto Network Switch" setting is on..
What Auto Network Switch does: when the WiFi gets too low the phone automatically switches to cellular, and when cellular connection gets too low, the phone will switch to WiFi
All Samsung Galaxy's are not alike for it's menu settings.. but you can try:
for S4 and up:
Settings>hold down on WiFi settings for a second then let go > un-check box at top for "Smart Network Switch"
for other Samsung Smartphones see the attached video below:
If your device is having issues trying to scan for your router.. try turning off your router for 2 minutes, then turn it back on.. make sure you wait a few minutes for your router to properly boot back up before you try scanning for your WiFi network again
Vodafone network unlock
To unlock your Samsung Galaxy S GT-I9000 from Vodafone Network ,you can use Unlock code. You can get the unlock code from MobileUnlockSolutions.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Samsung Galaxy S GT-I9000 .
I have a samsung galaxy gt-i9000 but my wifi nolonger works when i turn it on it says unable to scan twice then turns itself off.
Hello there,
You will need to be sure that there is wifi turned on in the area that you are trying to use your phone.
Then you try to go through the wifi list on the phone and delete all the wifi that it has ever seen and worked with. Then you turn off the phone for about 5 minutes, then you turn it on and turn on the wifi on the phone and search for the wifi available, that way it will search for the available wifi and connect to it.
Thank you for using fixya Caseytech
10helpful
I own Samsung galaxy s2. I have activated the data network mode but still not getting internet connection. even i cant see the ikon of data network activation on the screen
please visit the URL below which has perfect explanation with pictures and do everything in reverse..since this explains "How to Disable Data Network on Samsung Galaxy S GT-I9000"
so you need to make it ABLe...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://droidbar.net/2010/12/how-to-disable-data-network-on-samsung-galaxy-s-gt-i9000/
My samsung android galaxy S GT i9000 says data network not available when i try to call on send msg
make sure that data is turned on. When you pull down your 'message screen' by pulling your finger down from the top of the phone, you have several options like, wifi, gps... one should be for Mobile data. make sure this is turned on. if it is turned on, turn your phone off, take out the battery and sim card for ten minutes, then turn your phone back on and try again.
4helpful
2answers
I cannot remember my unlock pattern on my GT-I9000
You can try about the master reset system. Caution: All of your data will be lost that means your sms, notes, calender contact no.
please follow the instructions.
Samsung GT-i9000 Galaxy S hard reset
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 master reset
Please watch this video clips for unlock your Samsung Galaxy Phone. This may be helpful for you.
http://www.unlockedgsmquad.com/unlocked-samsung-galaxy-s-gt-i9000-feature-tour/
If you can't the consult with a professional technician who unlock your phone by using flash box tools. thank you so much.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
