Not likely. Chances are that while plowing snow, you overheated the transmission, causing the forward clutches to slip. Regardless, you should prepare to replace or rebuild it, keeping in mind that if it is going to be severe duty, such as snowplowing, you will want to add a transmission cooler as well as beefing up your internals. If it slipped once, it will surely do it again, until you lose all forward gears. It will still work great in reverse, in most cases.
