Ok this is not the correct way to wire this scenario up, you simple turn on the crossover on the back of the 2600 and send channel a to the sub which is crossed over inside the amp, and channel b will power both sp5s no problem. You can basically converting to a 3 way mono rig but the amp has all the crossover and routing necessary to add the 118 sub and power it appropriately, i do this all the time djing with the exact same gear list :) hope it helps
You would send high as well as low to the sub and unless the sub had a built in crossover it COULD get muddy sounding. The specs SEEM to indicate the 118 DOES have a low frequency crossover so it SHOULD be OK... How would it sound? An 18 inch sub normally adds to the sound of a system... You MAY need to PAN over to send more power to the one side with the extra load on one side. Often people use two sub's... one for each side so it is balanced.
