Hold the home and lock button at the same time and it should turn back on, have it charging when doing this
I have an apple iphone 4... idk y it turn off by its self all the time even if its on the charger. i try everything to turn it on.. but nothings works... so i jux leaave it alone and sumtimess it turn back on the next day... i need help because i really need to use my phone..
SOURCE: iphone 3g is frozen and touch screen wont work
If this unit is jailbroken you may want to do a full restore of the device, you will need to get the Iphone turned on and connect it to itunes, when you get into I tune and you phone is seen, right click on the device in itunes and tell it to restore.
This will reset the phone back to defaults, you will loose most of your data if not all.
If you can't get it to stay on or come on in Itunes then you may need to try this.
Step 1. Turn off your iPhone.
Step 2. Hold down the power and home button.
Step 3. When you see the Apple logo, release the power button but continue holding the home button down.
Step 4. Open iTunes and wait for it to tell you that its in restore mode.
Alternative Method:
Step 1. Connect iphone to USB then listen to the sound when it connect and disconnect.
Step 2. Hold the home and power buttons until hear the disconnect sound then release power button.
Step 3. Wait until you hear another sound then release home button.
SOURCE: iphone 3g locked and battery dead.
http://www.fixya.com/support/t267682-iphone_wont_charge
try my solution #10 ... good luck
