SOURCE: washer
remove dispenser drawer with rag and bleach water mix wash as good as you can the top of dispenser housing aroud holes to remove build up ..if problem is still there entire assembly will need to be removed and flushed thoroughly build up is blocking the holes over the dispenser cups
SOURCE: Kenmore Elite fabric softener won't drain
Is the dispenser full? It could be that it is a bit clogged. I would try just pouring a little very hot water in for several loads and using dryer softener sheets during this time. Let's see if we can unclog it .
SOURCE: Kenmore Elite Oasis, fabric softer thing exploded...
Okay...the cone actually goes inside the the two other pieces you mention. The cone is to be inserted upside-down. That is, the opening of the cone should be facing UP. The way this fabric softener dispenser is supposed to work is, you place fabric softener thorugh the opening of the dispenser. The cone actually holds it like a cup. When the washer goes through the initial spin cycle before the rinse cycle begins, the centrifugal force of the washer spinning forces the fabric softener out of the cone and into the wash tub.
The dispenser assembly should just snap right on top of the agitator. If the dispenser does not stay on securely any longer, you may have to replace it with a new one. You can find replacements at searspartsdirect.com. Just type in the same model number you provided and look for item number 1 under the "Motor, Basket and Tub Parts" heading.
I hope you find this information helpful. If you still have questions, please let me know.
PS It is also a good idea to periodically remove the dispenser and soak it in some hot water to get rid of accumulations of hardened softner. They will clog from time to time.
SOURCE: how to pull apart fabric softener dispenser
MOST DON COME APPART SOME HAVE A BLUE RING PUT IT UP AND PULL THE SOFTERNER UP AND PUT IN THE WASHER RUN A LOUD SMALL AND HOT WATER AND LET IT CLEAN IT SELF IN THE WAHSER
There should be a 7/16 bolt in the bottom of the cup once you have taken the cup out. Its kinda deep you would need a longer extension. Also this agitator bolt usually has a gasket material attached to it and it may be covered by another cap.
There's
never a good time for the washer to stop working correctly. If a
washing machine's agitator isn't working properly, your clothes won't
come clean.
The back-and-forth movement of the agitator is a main
function in the cleaning process of your laundry.
If your agitator
isn't working, it could be the agitator itself or broken splines in the
assembly beneath the agitator. Either one is a relatively easy and
inexpensive repair that you should be able to do yourself.
Instructions and material needed :Socket wrench,Rope,Broom,Replacement parts
