If we are talking about the water leaking out while you are taking a bath you need to take out the center section of the tip toe and replace it. You can buy a new replacement at any store that sells tubs and plumbing fixtures.
Now one of the things you might have trouble with is getting the tip toe top out. Take a channel lock and grab the whole top now use you muscle. Now turn it counter clock wise it should come out.
Just screw in a new one.
Now if it is leaking under the tub you have to do the same as above and now you have to remove the other section of the drain. You will see a "cross" with the hole that the tip toe screws into this will take a tool called a *********. Just line up the bell with the cross and it to turns out counter clock wise. Clean it and install some new putty and put it back the way it came apart.
Thanks for using us, and be safe while you work
Tom
Also if you could take a second to rate us it will help us serve you better if we know we are talking a way that you can understand.
