Acu-Rite AcuRite IndoorOutdoor Wireless Thermometer with Two Receivers Logo
Posted on Feb 28, 2018
I have an acurite wireless weather station that I purchased from COSCO. It still has seven days to go in its learning mode but the indoor and outdoor humidity values are way off. Is there a solution to this problem or should I take it back to COSCO for a refund? [email protected]
1 Related Answer
Anonymous
  • Posted on Sep 07, 2011
SOURCE: I have the Acurite 00604RX
how do i set my clock for accurite 00604RX
AcuRite Remote Sensor 00605TX for Acu-Rite 75321A1 Weather Station. I can't get my 00605TX to reset.
Question edited for a LOT more clarity. full 'make model (what it is)'.
Question moved from Computers to Model category.
Remove the batteries from both indoor and outdoor unit. Leave them out for 10 minutes. Replace the outdoor sensor with a new battery (2xAA), and then new batteries in the main unit (3xAA).
00605 Wireless Weather Station + Companion Instructions
AcuRite https://www.acurite.com > media > manuals > 0... PDF NOTE: When replacing the batteries for the wireless sensor, remove the batteries from the sensor and clear that sensor's channel on the main unit by pressing ...
6 pages
Hard Reset for Sensor Models 00606TX/06009RMA1 & ...
AcuRite https://support.acurite.com > en-us > articles > 360007...
The following reset steps can be performed to correct issues of the sensor not connecting to the display. Symptoms of the sensor not...
https://fccid.io/RNE00605TX/User-Manual/User-Manual-707183
My acurite 00509 has stopped giving me the correct temp reading. I've put another temp gauge next to it and acurite shows 78* and my othergauge shows 72*. Do I need to return it or what ? Thanks
The indoor temperature and humidity and outdoor temperature readings can be calibrated on the display to improve accuracy. Calibration can improve accuracy when sensor placement or environmental factors impact your data accuracy. 1. To access calibration mode, press AND HOLD the "?", "?", and "SET" buttons for at least 5 seconds. 2. Once in calibration mode, the preference you are currently setting will be highlighted on the display. 3. Press the "?" or "?" buttons to calibrate the data value higher or lower from the actual reading. 4. Press the "SET" button to confirm the calibration adjustment. The " " icon will remain illuminated next to calibrated values. 5. The next adjustable data will begin flashing, indicating it is ready to be calibrated. Repeat Steps 1 - 4 to calibrate additional data. The preference set order is as follows: OUTDOOR TEMPERATURE INDOOR TEMPERATURE INDOOR HUMIDITY BAROMETRIC PRESSURE (must be set to MANUAL mode; see page 12) After 20 seconds of inactivity, the display will save the adjustments and exit calibration mode. Note: Calibrations will be erased if the display is reset or if batteries are removed and the power adapter is unplugged.
1helpful
2answers
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
How do I set the time and date on my Thermor thermometer
Hold down the mode button for a few seconds > display starts to flash year > use +/- buttons to set year > press mode to present the month/day/time etc, again using +/- buttons
1helpful
Acurite wireless weather will not work new last season all new lithium batteries in right and were checked no picture #'s on screen
Hi Jerry,
While lithium batteries are recommended for the outdoor sensor it is not recommended they be used in the indoor display unit. Try using a good quality, fresh alkaline batteries and you should find your display turns back on.
1helpful
2answers
My AcuRite 00992 wireless weather station has suddenly quite displaying the outside humidity and dew point. Batteries are all new. I have lost my manual to troubleshoot this problem.
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Top Acu-Rite Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
