Are you at home, we cant guess wifi hot spots or the like.
it must be said, at home its a router,
and question 2 is , is it yours or MR , ISP's ???
if its yours than you are in charge.
The first thing to do is turn off WEP in any router, its insecure.
a great hazard that on.
set your rourter to wpa/wpa2
then using that laptop do the same, it will discover it and use what is broadcast from the router.
use a key pass word that others cant guess,
bam your in if not too far away, you never said how fare
1meter, 10 meters , 100 meters?
or router is behind brick or concrete walls...
we use router repeaters for that wifi. problem.
first off wifi is complex and very unreliable in the city..
(too many there, all fighting for 10 channels)
use wired, connections, unless mobile is badly needed.
my guess is you will ask how to setup a the unstated router.
learn that wep is not wpa.
they are not the same encryption at all.
wep has been cracked and is no good.
first get wired working
then do all updates and service packs installed
them the wifi card, driver loaded (from maker)
then
http://www.pcdied.com/DevMan/internet.ht...
Try this link might help you out.. Windows 7 wireless connectivity issue wpa psk not available Google Search
SOURCE: Vista wireless networking
What appears to be working is changing from TKIP to AES.
So far so good.
