This is a common problem on these sets. As the menu is fine, this is highly suggestive of an internal failure.you have a driver board failing if you would open the set and on the
left side is the Y-sustain board there are two boards connected to the Y
SUS board. The one on the top drives the top half of the picture and
the one on the bottom drives the lower half of the picture open the
ribbon cables make sure to clean it or Re solder if you see needed turn
set on and test, sometimes cleaning this will fix problem sometimes re
soldering will fix problem and last resort is, the board itself is bad.Unfortunately,you need to diagnose and inspect all the components before replacing any part.If you wish to repair it yourself, i could give you a link to buy the service manual and would upload a troubleshooting chart ( generic ) that would explain how you need to diagnose the fault when you open the TV.However, there is no quick fix. It has to be opened and tested and then diagnosed.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Thanks for your response!!
You could view the manual without any charge from :-
http://www.scribd.com/doc/42952992/LG-DU...
The above manual cannot be downloaded, however,you could view it without any fee.If you have any problem or need troubleshooting guide, revert and i would be able to follow up.
Thanks and Regards
taran_2005
I do not think that the creen is broken because it displays the menu very nice and crispy.
Thanks for your response. I like the answer. I would love to have that link to the repair manual.
The solution makes lots of sense. I have not repaired the TV yet, but it helped me to ID the parts of the TV.
