The F1 error code indicates that the signal from the water level pressure switch on the machine control board is out of the normal range. This can be caused by the pressure hose between the bottom of the tub and the pressure switch being pinched, twisted or kinked. If this pressure hose is okay, then the machine control board will need to be replaced to correct this problem.
