SOURCE: chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
SOURCE: BOSCH WFMC3200UC WASHER
Go to http://www.repairclinic.com/SmartSearch/smartsearch.aspx and type WFMC3200UC under search at top. Then select gasket/seal/o-ring from part type drop down menu.
SOURCE: front loading washer leaks
The rubber seal (or bellow) wears with age and will eventually deteriorate over time. Excessive use of detergent, and/or use of the wrong detergent (detergent that is not HE) can contribute to rubber breakdown too. Regular detergent is formulated for washers that use a wash tub with a capacity of 35 gallons. HE detergent is formulated for High Efficiency washers that only use 5 to 7 gallons of water. So, if you place regular detergent in an HE washer, you are (in affect) putting a higher concentration of soap in your washer. This higher concentration of soap can act as a corrosive to rubber and become permeated in your clothing as it does not rinse completely. This can lead to skin irritations as well. It is important that if you are not using HE detergent that you do so in the future to prevent premature breakdown of the rubber seals of the washer and pump. This will also void most manufacturer warranties if it determined you are using improper detergent. Now...I'm not trying to accuse you of abusing your appliance and not trying to lecture you. I'm merely putting this information out, because some people simply do not know. Overloading the washer is another contributor to excessive wear on the bellow as well as not keeping the bellow cleaned properly. Mold and mildew can contribute to the break down of rubber. The following link can give some advice on proper care of the door bellow:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
Since your bellow is already leaking, it must be replaced. Replacements can be ordered on line at either searspartsdirect.com, repairclinic.com, or pcappliancerepair.com. All these websites offer competitive pricing, so you can shop for the best deals. Just type in your COMPLETE model number to begin your search. The Sears website offers helpful exploded view diagrams to assist in part identification and location. NOTE: You may consider ordering the front and rear bellow clamps if yours are damaged. Refer to the Sears website for pictorial view.
If you need assistance in replacing the bellow, the following link will give you the steps necessary to complete this repair on your own:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
SOURCE: remove bosch axxis 2060 washer motor
Remove the back panel to get to the motor which is at the bottom at the back. Notice two bolts holding the motor into the mount. Remove these two bolts. Notice the back part of the motor is sitting in the mount with black rubber washers. Carefully, pull the motor forward, and this will be abit hard. You can take a flat head screw driver and tap down (in between) on each front plastic washer and the motor will slowly come forward. Becarefull because there is a wire harness still attached to the motor. You have to take wire cutters and clip the placstic band holding the wire harness to the motor. Then grip the harness and wiggle it free. Then remove the single wire also. Putting the belt back is a bit tricky too. Make sure you put back the two black rubber washers and the two front plastic washers.
SOURCE: Bosch Axxis Washer Detergent slot codes; what do they mean?
soap goes in far left
softner middle
liquid all fabric bleach or powder bleach in far right
