That error indicates that you need to replace the Engine board. The part number is 11K1416, a service tech would need to replace it due to settings needing to be reset.
You can change the language on your Lexmark Optra T610 by pressing right arrow Menu button 6 times -> select Printer Language (first option to appear), hit Select -> select preferred language, hit Select button to save.
Hope this helps. Thanks.
Sounds like you've experienced a fairly common problem with Lexmark Optra printers. The engine board has more than likely failed. Rather than go to to Lexmark, try this site for a less expensive replacement board...
Here's an article in the Lexmark website to clear the NVRAM Failure. Just click on this link: http://bit.ly/bGSdYV. Hope this helps. If you need more assistance, just place a comment and I'll be more than willing to help you out. Thanks.
replace printhead - scanner assembly. The scanner motor is not working correctly. Need to remove side covers, back of printer assembly, the top cover. Printhead is below the top cover
