My grandsons broke their mother's (and aunts') FP music box.
There was almost no sound
The teeth are simply a wind-up music box set, connected to a rod that transmits the vibrations to the diaphragm under the pseudo-tone-arm. I was able to fix by placing a cotter-pin on the rod in the arm at or near the junction and then trim with wire cutters to the correct size.
I checked the diaphragm first by tapping it through the arm/table connection.
SOURCE: how to open FP music box record player, #995 or #995N
Fisher Price Music box: to open, remove the four screws from the bottom, open the two parts as wide as possible without using too much force. Using a small flat blade screw driver, insert between the red cover and white top where the wind up knob is located. Pry the red bottom out far enough to allow the ring surrounding the knob to slide under the red bottom. The box is now open.
After repair, and re-assembling, make sure the wider part of the wind up stop wheel faces the front of the player, otherwise the wind up knob catches and slows the mechanism.
Remove 4 screws. Pry open about 1/4 inch, just enough to insert red straw attached to your WD40 nozzle. Lubricate metal parts inside near the stem of the yellow wind-up knob. Lubricate metal wheels under the armature. That did the job for us! Player seems to operate at normal speed.
