Toshiba Satellite Pro A210-EZ2202X Notebook Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pressing f12 it shows me a password request for bios.what can i do?
Anonymous
Level 3:
  • Master 2,296 Answers
  • Posted on Feb 04, 2011
Anonymous
Master
Level 3:
Answers
2296
Questions
0
Helped
833575
Points
6040
You can reset the password if you don't know it. To reset the BIOS password read the information from this link http://www.fixya.com/support/r7229632-reset_or_remove_bios_password
2answers
Got an Acer 4050 from ebay and it goes straight to enter boot password
can you click on f12 before it goes to boot password?
The F12 Boot Menu allows you to choose which device that you would like to boot the computer's Operating System from by pressing the F12 key during the computer's Power On Self Test, or POST process. Some notebook and netbook models have the F12 Boot Menu disabled by default.
If this sounds like your problem then try this:
If this sounds like
To enable the F12 Boot Menu:
  1. Restart the computer.
  2. Press the F2 key to enter computer's BIOS Setup during Power-On Self-Test, or POST, process while the Acer logo is being displayed.
  3. Press the Right Arrow key to select Main
  4. Select F12 Boot Menu
  5. Press the Enter key
  6. Select Enabled
  7. Press the Enter key
  8. Press the F10 key and then press the Enter key to save the changes and restart the computer.
Note: Not all Acer notebooks or netbooks have the F12 Boot Menu feature. Computers that do not have the F12 Boot Menu feature will not be able to enable the feature within the BIOS. I hope this works for you if not, then the problem is obviously not the boot menu. Go to Acer support for more help
I have a Dell Demision 3000 Series, it shows black screen when I try to reboot it displays adminstrator password required, I had this computer so long I dont know where to get the password.
first unplug all power from your computer. Next open the side panel of the desktop. Inside the computer you will see the motherboard. locate the battery ( round flat like a quarter size, silver color). Carefully ( very carefully) remove it. Wait 10 seconds and reinstalled it. This will reset all your cmos or bios setting to factory setting including deleting your password.
4helpful
3answers
How do I access the screen that shows BIOS options as I wish to upload UBUNTU 11.04 from a pendrive, so I want to make my first and possibly second BIOS options to be for the pendrive.
At boot time repeatedly pressing either, F2 , F12, or possibly Fn+F1 this is depending upon the bios wether it has been updated or upgraded. One of these should do the trick.....
Bios password setup for acer aspire 5610
when you start your pc enter the bios setting pressing F2 normally.. once there you can find the security option and bios password is in there type the password you would like and press F12 nomally to exit the bios with saving
2helpful
Reset bios password
restart your computer and when it comes back on press for bios it may be the F2 button or Del button ect..... once in bios select security and bios password options will be in there choose your password and exit&save by pressing F12 normally
How to remove bois password
When you first start the computer, rapidly press F12. When bios shows up navigate to password and delete it. The button might also be F10. Most laptops are F12 but some vary. Hope this helps.
2answers
When I turn notebook on it only powers to the screen that says f2 for set up or f12 for boot options, occasionally I can hold the f12 key while powering up notebook, release key when it comes to that...
try to reset the bios to factory defaults to do that keep tapping the f2 key as soon a you turn on the computer until you see the bios screen then using keyboard go to a tab which says boot then press f9 key press 'y' to confirm then your computer should boot properly everytime..
take a look at this picture just to show you how that screen looks if this doesn't work try doing system restore..to do system restore try this link..see the use system restore topic
How to reset the bios password for nec versa m350.. pls help!!! i want to reinstall my OS but i can't access the bios setup to change the settings to boot from cd rom upon startup. there is a bios...
Restart the computer, and read the first message (white text on a black background), hoping that it says something like "press F1 to enter BIOS setup, press F12 to select boot priority".
If it does, press F12, and then select the CD-ROM device as the "bootable" device.
2answers
Acer extensa 5220. how ;open bios? f2 or f10 or f12 or what?
Try On bootup you should either Press 'DEL' or 'F1' or 'F2' to enter the BIOS
2answers
Administrator password help/ password boot cd
Hello pink,
In order for your PC to read your CD on boot, you don't have to enter your BIOS settings. When you start your computer, press the F12 button repeatedly (like F12-F12-F12-F12), and your pc will ask you which boot device you would like to use.
http://ice.he.net/~hedden//images/F2_for_Setup_Dell.jpg
It will show you a screen like this:
http://www.prime-expert.com/ebcd/img/bios8.png
Just select your CDROM in the list, and hit enter. this will read your bootable CD.
I hope this helps.
Jerry.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
