Press and hold the Windows key and the letter 'R' together.
When the Run window pops, enter the command "temp", without quotes, and press Enter key.
Now, you will have Explorer Window with the system junk files location open.
Select any file or folder in the Window and then press and hold the 'CTRL' and alphabet 'A' at once.
Now, right click the selected files.
While holding down the 'Shift' key, select the option "Delete" from the pop up menu.
If you are prompted to click on 'Yes' or 'Allow' or 'Continue', select the check box to the left bottom corner of the pop up window and then click on the visible button mentioned.
Repeat the step 7. If the pop ups continue for more than a few times, select the option to the left bottom corner of the pop up window and click on 'Skip' and repeat the same.
Once deleting is complete, you may close the Temp folder window and continue to next step.
B. Cleaning %temp% folder
The steps to clean the user related junk files is to follow the same steps above to delete the temp folder as above, where the command 'temp' is replaced with "%temp%", without quotes.
Error 23, 28, 29, 1011, 1012, 1611: These errors may indicate a hardware issue with your device. The best test is to Try and restore from another cpu. Follow the steps in this article and also attempt to restore while connected to a known-good computer and network to isolate this issue to the device. If the IMEI or MAC address is missing or is a default value, this can also confirm a hardware issue.
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p... 421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
I have found several different solutions that may help you ,try Google and type in the search engine
DXE legacy Option ROM Initialize error,(1011 0010)
There are several post that will walk you through some procedures,too much to get into on this site.
Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem. If you can't solve the problem, you need to replace the asus eee pc 1011 keyboard. we supply high quality and low price asus eee pc 1011 keyboard.
