Panasonic KXDT333   Phone Logo
A
Anonymous Posted on Jan 17, 2011
How do you record a new message on the kxdt333 phone
How can i change the message on my panasonic KXDT333
http://www.key-comm.com/kxdt333343346systemmanagersguide.aspx
Record greeting
to record greeting message on your pbx, you need to have COS64
assigned to your ext. then press *36 1 501 to record greeting
When I lift receiver LCD shows Recorder Tone, how do I remove this.
Sounds like a hot dial is set Press *790 then lift the receiver IMPORTANT do no lift the receiver first
Please do you have a copy of the manual for KXDT333 to download
Hello. Here:
http://service.us.panasonic.com/OPERMANPDF/KXDT333.PDF
Your welcome:)
How to change recorded message
When your system was installed, you probably should have been paying attention or asking the installer some questions. Each system is different, but the recordings are controlled from mailbox 998, the message manager's mailbox. The newer Panasonic VM systems assign custom greetings sequentially and usually we put company greetings in the first 3 or 4 slots. They're fairly easy to find and administer if you have a password and some time.
Carl
1helpful
I have the red light constantly on my panasonic kx-dt333, but i have no messages to listen too. how can i turn this light off?
Press MESSAGES and look at the display. It will tell you where the message came from and the 3rd softkey will let you erase the message.
l
Car
2answers
How do I setup my voicemail to my KXDT333 on a SECOND line (with a different voicemail if possible)?
Dial your extension. Wait for the greeting to say that you are at your voice mailbox. This is also the "Quick Voice Mail Tutorial Set Up."
Follow the instructions provided in the tutorial. You will be asked to enter your name (or company name), password and greeting. Write down the password and keep it in a safe place.
Record other greetings, if needed. After the tutorial, you have an option to add different messages for different situations. Press "311" to change your general greeting. Use "312" to record a message for when the line is busy. Dial "315" to record a temporary greeting for when you are away for an extended period of time, such as vacation.
In addition, visit this link below and read the information on page 9. I think it will be of help.
Good luck.
4helpful
The red message light stays on when all messages have been deleted.How do I get the light off.
On your idle phone, press MESSAGE and look at the display. It will tell you where the message came from and the 3rd sfot key will let you CLEAR the entry.
When they're all gone, the light goes out :-)
How do you change the answering machine message?
In a Panasonic TVA voice mail system, there are 100+32 different boxes that you can record into. We supply the map and directions at installation. Try contacting whoever put the system in, or look around for some paperwork and software to access the VM.
Unlike the old TVS systems, where we put the Day, Night, and Holiday greetings in specific boxes, the TVA has that visual **** and you don't get the opportunity to lock the greetings into specific boxes. Now, it's just sort of numeric.
Carl
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
