Sony KP43T75GRAY 43" Rear Projection Television Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yes my Sony KP43T75GRAY 43 in. Rear Projection TV worked beautiful before I placed it in storage for about 7 months. Now it has a slight green haze on everything. What should I do? I was told to remove the back and clean all the lenses. Advice....
Chi Chu
Level 3:
  • Sony Master 8,457 Answers
  • Posted on Jan 17, 2011
Chi Chu
Sony Master
Level 3:
Answers
8457
Questions
0
Helped
2822797
Points
26282
The DLP tv alway have problems with it convergence board problems.Tries flash focus button or manual + - convergence R,G,B colors lines alignments up.Still have the same problems,the convergence board is dead or have problems,convergence board must be fix to solved the green haze problems.
SONY KP43T75/NO PICTURE, RED LIGHT ON INDICATER
Very old set and if red power light stays on and does not blink about a dozen different possible reasons----many parts no longer available for this set----I would retire it and buy a new set.
3helpful
2answers
Sony rear projection tv
How long have this tv had it picture bulb,change before for this tv?Longtime usage,picture bulb the first,must change.
Hitachi 50c20 rear projection
If this is a tube projection then the oil may need to be changed in the one or more of the tubes
KP-43t75 no picture black screen, Menu comes up bowed
Ur convergence it dead.Buy a convergence kit,replaced what in that kit.Know how to solders right?Buy a convergence kit in these websites Tv repair World.com,Tv rpair Kits.
Will My Sony work Overseas
your users manual should tell you if it is a pal and ntsc system it will, thay do make ntsc to PAL convershiom box cost about $139
Sony tv kv24ls35u 11 blinks
Sony does not have 11 blink code it only goes to 10 blinks. You can Try self-Diagnostic mode- Press---- display,5,vol- then power when set comes up it should have codes telling you which circuit has problem.
Sony 11 blinks
Blink code only goes to 8 on this model. Are you sure its not 5 and 6? That would be AKB and Horizontal stop, respectively. Quite likely a flyback transformer on this model.
Green haze not sharp
Good Day;
Sounds like your TV has a convergence problem. If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram. Or call FACTORY SERVICE;
1-800-448-2244.
Good Luck, big IRISH. PS or get from HIT Part X480293: kit.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
