Cars & Trucks Logo
Posted on Jan 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It start and runs 10 to 15 mins at an idle then shuts off. starts make up and runs for 2 to 3 min and then shuts back off. i have replaced crank shaft position sensor, fuel pump, fuel filter,run fuel pressure test held at 30 psi steady. Tested the coils they are good. Can let it sit for 10 min will start up and idle 10 15 min and shut off again. Can you help have run out of ideas. Thanks, Jim
Anonymous
Level 2:
New Friend:
  • Expert 120 Answers
  • Posted on Jan 17, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
120
Questions
Helped
31002
Points
375
Hey Jim why havent you replaced the Ign module?It sounds typical of it. Good job checking fuel pressure BTW most dont.
Hi can any1 help me with my nissan sentra problem?my car just shut off while driving and lost power be for it shut completely off tried to crank it back up but it didn't start sprayed some starter
Crank shaft sensors often fail without triggering a code. But in its early stages, a check engine light may be on. Symtoms of a bad crank sensor are: poor acceleration ( lack of power ) rough idle, ETC. sometimes you may be able to start it normally, and other times it takes 3 or more times. If the check engine light is on take it to a auto parts store and thy can read the code for free. To tell if that's the problem. God-Bless!
1994 f150 6 cyl engine shuts down every 10 min restart after 5 min
Sounds like the module inside the distributor. Have to be replaced.
2answers
My son left the dome light on all night. Replaced the battery. The truck starts but will not stay running. Ran perfect when I parked it.
The computer has lost its memory for idle control possibly.Try this, crank the truck and shut is off.Do this as many as 20 times , each time try to leave it running for 2 or 3 seconds so you can see if it will idle on its own.Do this till it relearns base idle.
First started not cranking after shutting off say to fill up, mite wait 5 min or a few hours and it will crank and be fine for weeks. now it started like losing power and going dead. agan may wait 5 min or...
Might be two problems, but one is your igniter in the distributor. The second, the idling problem is either your throttle position sensor, or a vacuum leak. With the engine running , check all hoses for leaks by wiggling them around, while listening for a hissing. Check intake bolts for tightness.
2helpful
2answers
Vehicle will not start for 15 t0 20 min.after
Could be several problems with a car that old:
1. Weak coil
2. Failing fuel pump
3. Failing crank sensor
4. Failing mass airflow sensor
94 chrysler con.3.3 eng.runs for about 15 min. shuts down,engine
suggest change crank sensor-rear of engine pas side
3helpful
1999 Pontiac Sunfire ignition lock cylinder changed but car has anti theft and car wont start. How can I get it to start?
try turning the ignition on try to start then without shutting key off wait 10 mins then shut key off then back on but do not try starting leave on for ten mins then back off turn key back on to run but do not try starting it wait ten mins then if it reset it should crank over and start if not repeat all steps again
1993 altima will crank but will not start..
replace the distributor oil is leaking into the electronics of the distributor and shorting out pull cap back off and look and see if oil is leaking out
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
