This means that either the switch is bad, the wiring is corroded, the fan is not working, or the air switch tubing is broken or cracked. Follow the air switch tubing all the way to the end, remove it and check for cracks. This is the most common. Also check wiring connections for breaks, or corrosion.
If all looks well, replace the air switch.
Also, before any of this, make sure the fan is coming on at start-up.
